I finally got my VAC running. The points were not opening up. Now it runs well, but pull starts only. Battery is charged. Bad coil or condensor?
But about the brakes...the left brake has a high peddle when backing up, but considerably lower when going forward. And if I back up while he's doing the brake pads he peddle will come up. What do you suppose the problem is?
Thank you,
Glenn F.
Thank you,
Glenn F.
