onedirtyhat
New User
Hey everyone. Just bought my first tractor knowing it needs a little work. Here are the issues with the Case 930 diesel;
1. 3pt hitch won't lower. I do know that the remotes work and have the correct pressure that they should. Is there some sort of valve that could just be stuck or gunked up?
2. PTO will not stop spinning. I can turn the shaft by hand when the tractor is off. When the tractor is running, If an implement is hooked up to it and the pto is off, it wont spin. Is there some sort of brake or clutch in the pto housing I should check out?
3. Lastly, on start up I get an intermittent pop and puff of white smoke for about the first 5 minutes. After that, no more pops or smoke and she runs really strong. Any ideas?
Any advice will be greatly appreciated.
Thanks.
Thanks.
