Sealing drain plugs: is there a Teflon tape?
DennisT
Getting ready to put the transmission drain plugs back in my '53 SC. I thought I'd heard of a Teflon sealing tape for oil-based fluids similar to what most of us have used for household water pipes. Anyone know? Not sure I want to trust the white Teflon household stuff to a 90W oil drain plug. The larger plug on my SC was nice and tight when I removed it, but it had been seeping ever so slightly over time. Now's the time to help it stay dry with the new fluid.
?? Dennis in E WA state
Teflon tape works Very well for oil,, wrap it on the direction it screws in,,, liquid Teflon is a joke if you have a spec of oil on the threads tape does not care
I don't think you would have trouble using white Teflon . I worked for Prentice log loaders for 39 years and that is what we used on all of the pipe threaded fittings.
There is a chemical resistant version of Teflon tape. I get it at Home Depot. it is yellow and a little thicker than the white.
I think most us army HET's hydraulic lines had abundant amounts of white tef tape applied to them. Stopped the leakage problems even with the hydraulic pressure involved
