Hydraulic Pump
Started working on gas tank leak and noticed that there was a large pool of hydraulic oil on the floor coming from my hydraulic pump ( 48' VAC with the High Pressure Pump off Belt Pulley ). Looks at though it's seeping from one of the shafts coming off the side of pump. Book doesn't show that shaft is removable, so wondering what remedy someone has used to stop similar leaks. Not sure what might work. Any ideas appreciated.!!
Mike
Do I run it through the pump, or coat the outside.? Worried that if I put it inside pump, it might cause issues with the pistons working properly.
By the way, saw nice pic of you and Sara at ST. Mary's Festival.
Mike
I assume you are referring to the control shaft. There is a packing with a gland nut that seals it. Will need a thin jaw 3/4" open end wrench to tighten it. Lee
Will check about that nut, but not sure which of the 2 is leaking for sure. Trying to get tractor back running, need to mow pasture down.
Mike
put it in the pump,,,lol ,, and run it ,,. sposed to swell old dry seals and givethembody and make them seal ,, if they are not too woreout thaty is ,,,also helps clear gunk and sticky pressure springs ect ,,,btw , we did our annual church picnic dinner ,, served over 4000 folks ,, great weather too ..
