430 Water temp sensor
I have a 1966 430 diesel. I want to add an aftermarket water temp gauge. What port on the engine would I use to install said gauge?
I don't know if it has the same engine, but on my 470 it goes on the right side, near the rear, above the starter and selanoid
Ah mine has a port there to!!!! Must be the same or similar engine. That's where my temp gauge will go. And what kind of temps should I call normal? 150-170 degrees?
