Mine is a propane, and right now I can't get regulator to function. I did get the crank freed up and the engine back together. I put 4 3/4" M & W high compression pistons in it, plus the high compression head. Anxious to give it a pull!
John,
I pulled the starter out and used a bar on ring gear. It was stuck sraight up and down for some reason. It's loose know and I have the motor back together. I have to get a different propane regulator, mine is not working properly. Thanks for getting me the parts out!
