PTO shaft driven belt pulley
oldproudvet
Gentlemen: I've a chance to pick up a rear mounted (4 flange bolted) PTO belt drive. This came off my uncle's 500 that he bought in the 60s. The tractor is long gone and he ran across this in one of his sheds. Would this bolt up to my 830CK? My sales lit shows one is offered for this tractor and I'm just wondering if they were the same thru the model line. Thanks!
I would like to check that part # against what the 411 uses. the part# for the belt pulley housing is A7398. Let me know what you find out .
(quoted from post at 00:08:14 08/07/15) I would like to check that part # against what the 411 uses. the part# for the belt pulley housing is A7398. Let me know what you find out .
411, or 411B? I have a belt bully for a 411 that fits on the side of the transmission. The belt pulley assembly for a 411B fits on the PTO.
Hi Chuck - The casting number is G-1297 and the bolt spacing around the mounting flange is 5.5" in both directions. This will not work on my CK as the horizontal spacing over the pto is 5.5 but the verticle is 3.5 My 401 big diesel is backed up against a shed wall and I can't get a good look @ the pto area. The pictures will show you the unit. So I answered my own question, it won't fit. My real 400 has the torque tube mounted pto.
I am interested in the side mount belt pulley setup that fits a large Case 400. If you are interested in selling it please contact me by email.
Thanks!
(quoted from post at 17:52:50 08/09/15) I am interested in the side mount belt pulley setup that fits a large Case 400. If you are interested in selling it please contact me by email.
Thanks!
Your email isn't open.
The [Send Email] option appears to be available the post you replied to. Yours and other posts still say [No Email]. Please check again.
Thanks
Joe
(quoted from post at 01:11:02 08/10/15) The [Send Email] option appears to be available the post you replied to. Yours and other posts still say [No Email]. Please check again.
Thanks
Joe
I'm looking at your post right now. The email button should be next to the profile button on the lower left corner of the posting, but it's not there. I see it on my posting. My email is [email protected]
