930 wheat land missing
460anger
just got it home its a diesel idols like a watch get after it starts missing will not clear up going to start with fuel filters any other thoughts ???
Crack each line one at a time at the injector that will tell you which one is causing the problem. I changed out all my filters and drained the old fuel out of the tank. Two cans of Seafoam in 10 gals of fuel, worked it hard and runs great now. Good Luck. Others on here can tell you how to pull these and the power cell never had to do that
After cracking lines to find the missing cylinder, maybe check valve clearance.
930 6 speed transmission.....intake .012 cold...exhaust .020 cold.
930 8 speed transmission....int. and exh. .020 hot.
