So last night while baling i got some chatter in my hydraulic system coming from the shifter valve/remote lever area and then i lost all forward movement, pto , steering and brakes. I have had a trans filter warning light come on sometimes while idling, and my hydraulic seat has been acting up as well This happened to me 200hrs ago but the chatter was much different and no filter warning light ever came on. It turned out to be the charge pump drive bevel gear was shelled out. Is it a common problem when working the PTO on a large baler to have the gear shell out? Could a faulty pump be to blame? could vibration from the baler on the pto system cause any problems? Any thoughts would be appreciated, thanks
