carpetfarmer
I'm adding all new work lights to my Case 1190 and need some help identifying a relay...I know what I want, but I don't know the proper terminology to find one. I currently have a relay similar to the one pictured but once the coil is activated, the relay doesn't deactivate until the whole thing is powered down.
The light switch has 3 positions and I have it wired up so that the front lights are on when the switch is in the 1st position. When its in the 2nd position the front and rear lights are on and when the switch is in the 3rd position, the front, rear and front "brights" are all on. The relay works great turning them on, but they don't shut down in the same manner. When you shut them down, you turn the knob back down to the 2nd position, everything stays on until you turn the knob all the way back down to the 1st position which then turns off both the brights and the rear work lights. It's not a major problem by any means but I would like it work like your normal tractor lights.
I'm looking for a relay that deactivates when the coil is deactivated, what would be the proper terminology for one of these, if it is possible?
Thank you,
carpetfarmer
Thank you,
carpetfarmer
