230 J.I. CASE square baler
I just bought a CASE 230 square baler and it has a broken cog on the knotter the one atached to the to the stainless like needle nose part i would be interested in a hole assembly or just the cog it looks the same as my dads 220. Thanks Loren
Just a update on the 230 pinion knotter hook drive i looked at my neighbors new holland 273 hayliner the gear looked the same so i ordered one fron cnh it is almost the same billhook shaft is a little bigger on CASE so i took a air die grinder to it made to hole in the gear bigger to slide on my shaft. I will update after i try baling but things are looking good. Thanks casecollectorsc.
Loren
well i tried the 230 out today on my 830 ck baled 30 bales 3 times before it started tying right was working really good wen we quit hopfully tomorrow goes as good as the last 20 bales. really nice bales tho nice and square tight bales 70ish pounds i would say. real happy with it.
Loren
