Case 580 C Backhoe
wratchet
Case Backhoe 580 C Shuttle shift works great in reverse but has its problems forwards. If full of oil works ok and I know that is the problem. I would like to replace the hyd shuttle as it leaks badly when trying to move forward. If I ease forward it does not leak as badly buy--sometimes I rerally want to move? Does anyone know of repeair kits or replacements? I do not know Case tyractor very good but it appears this shuttle is directly behind and mounted to the engine? Can it be repaired?
Case used to offer a factory reman
, but I've been away from the shop
for years . Call 'em and check .
They are pretty simple except for
shimmimg the forward clutch pack.
Gotta be real accurate !
