A look inside the 300 transmission.
connor9988
Location
Central Iowa
Opened up the transmission to get ready to replace the speedometer cable. The gears look good. There are only a few nicks and chips but It should still run good.
Where did you get the cable? The one on my 310 went south last fall. It was a cheapie that I had to swage one end on. I want one that is complete custom fit. They all seem to be too short for a proper radius or way to long.
Joe
Joe: We stock the complete correct Cable & Housing Assemblies. Genuine CASE $$$ or a very economical aftermarket.
John, I have checked your site before. All I see is the tach cable. Is it the same as the speedo cable, seems it would be a little short for the 180 routing? I don't want that universal cable.
You're right about cross-ref on belts. Close might not be good enough. You have to do some measuring and match up to their info page on the belt.
Joe
