Spark Plug wires
I got mine for my DC from Kuhn's. American made wires. Seems to be good wires. I'm sure NAPA would have a good set. The reason I went ahead an purchased these is I was ordering other thing too
I use spark plug straight wire, off a spool. No resistance or carbon wire you can pick high quality silicone boots and BRASS ends to crimp or solder. They'll outlive us all. The older gas engines, particularly magneto powered, lack the intensity to fire thru carbon wire. They will work, but you're using up voltage pushing thru the wire. The systems were not designed for carbon wire.
If you have a Baxter auto parts store there, you should be able to buy bulk cable there. NAPA would probably have some as well.
