Hi there new to the forum and case tractor, I recently inherited a case 511B tractor with a three point mower attached to it and had a question. I am having problems with the hydraulics to raise the mower the engine has to be running at a high rate of speed then it is jerky going up then if I let the mower down it goes down with a bang. Is there a hydraulic filter in the system if so where is it located? And where is the oil level for the hydraulics located? I found a dipstick on the big 1 1/8 nut in front of the seat is that where the level is checked? And how is the oil level for the final drives checked did not see a dipstick for that on the tractor. Or could there be something wrong with the hydraulic valve body itself? Thanks in advance for any help.
