Lift quadrant friction disc
Tom N MS
Case 990 1970 model --need lift lever friction disc--lever is totally loose-moves up and down with no resistance..where can I get this part? Thanks
If it's a true "friction" disc, a local clutch brake relining shop will have friction material of all thickness. Determine how thick
you'd like it, buy a bit and use a hole saw to cut the diameter. It works great. I built new ones like that for my 1070 door, my SC
throttle, my skid steer throttle etc.
