John Saeli
Finally, this afternoon, got the Steering fixed. For those of you following this saga, hopefully, someone will gleen something from this to maybe use later. 3 weeks ago rear steering went screwy. Did all the tests, and they pointed to a rear sensor problem. Pulled the rear sensor & bench tested, & it proved faulty. Bought a "Re-Man" Sensor from CASE, installed it & everything was fine. Steering worked well. Went back & weather proofed the connections, sealed everything up & rear steering was worse than before. Welcome to John Saeli's Bizzaro World!! I knew it was too easy!! Anyways, I ordered a new rear harness, replaced that this afternoon and Finally, all is good. Had a double whammy.
