VAC Eagle Hitch Progress
connor9988
Location
Central Iowa
Started digging into the eagle hitch on the VAC today. Used a hex key on a socket to get the bolts out. (bought at a hardware store) The cylinder looks good, tight, and clean with nothing in the bottom portion of the rockshaft so we reassembled it. The guess right now is that the valve/lever assembly to the eagle hitch is badly worn and needs shimmed or de-shimmed.
