David Brown 770 Lift Pump Failure
Traditional Farmer
Location
Virginia
Had a new aftermarket lift pump for awhile and finally put it on my DB 770 tractor ran great and it worked fine for about 2 hours then it quit.Took it apart and the piece in top that holds the pump plunger broke off.Anyone else had this happen or did I just get a bad one?
The aftermarket ones that don't have a glass bowl are sketchy at best. I always rebuild the originals. Sparex has the kits cheap.
