tractor radios
chuck machinist
I searched the archives for Case tractor radios, and and came up with a blank. I found one that has the newer case logo. I was going to mount one on the 411 for nostalgic reasons,but how about some ideas on where you all mounted yours on an open station.Thanks in advance .
To keep the vibration down, I made a radio stand from 5" pipe. Flat plate on the bottom and 45* angle so it follows the fender.
1" pipe straight up coming out of 5" pipe to mount radio. The old radios had a flat plate and 1" pipe base with a set screw to attach to the mount. Clear as mud?? Got one laying around here from the 70's some place. Bolts to the axle between the foot stand and fender.
Thanks Steve,
Mounting to the fender would probably shake her a bit. I know I could wear a set of head phones but it would not be the same. hey!
