sticky trans slide
case444john
New User
I just picked up a 1971 Case 444 and am restoring it.
The shift rod is stuck in the inward position (hi gear?) and I can't get it to pull out. any suggestions. I don't want to break anything.
You may need to use some gentel persausion to move it !! The shifting shaft has a fork on a slideing collar and you may need to rock the tractor to get the collar to align with the low gear. Just play with the shaft a bit and it should slide in and out, to change ranges.
Loren
