1175 clutch
DC3puller
Put nine more springs in the preasure plate and a heavy duty disc. Put tractor back together would not disengage to shift gears also labored engine a little when pedal depressed any Ideas? We adjusted pedal distance
Same thing happened on our tractor when we did the same thing. found if you let the pedal back just a bit worked ok so we just made a new pedal stop. I never could figure this out why either because nothing else was changed except the added springs and a button clutch. almost seemed like the clutch was going over center and reengaging. Try not pushing the pedal all the way though and see if it works then
