730 CK hudraulics from below
JCCWI
Finally found fact. specs for hydraulics and on its best day the old 730 would not have been able to raise the old JD haybine....just not enough hydraulic pressure.
John
I have a 730 CK Case. I put a 6 row corn planter on it loaded with dry fert and it lifts it of the ground. I plug a 5000 psi guage into my back hydraulics I think it was around 2500 psi. My 730 eagle hitch tractor would not be able to pick the planter up. Not sure, the eagle hitch tractor puts out around 1600 psi. I have done alot of hay cutting on a 730 eagle hitch and a 479 New Holland haybine. It was slow to raise but you planned for it at the end of the field.
