Which parts manual to order
Jake1991
I have a 1959 Case 801B. I am trying to get a parts manual for it, but the only manual I can find is for a 800B. I know the 801B is a variant of the 800B, so would the parts manual be relevent? Any input would be great. Also, does anyone know where I could find a working insturment cluster and guages? Or know where I can get mine rebuilt? Thanks!
a "800B" IS a 801B the serial tag has the "model" stamped on it, meaning how it was built, standard axles or adjustable gas or dsl, that is what the tag number tells you, the book you found is what you need, it covers all variations
cnt
(quoted from post at 08:37:41 06/05/15) a "800B" IS a 801B the serial tag has the "model" stamped on it, meaning how it was built, standard axles or adjustable gas or dsl, that is what the tag number tells you, the book you found is what you need, it covers all variations
cnt
Awesome. Thanks Case Nutty. You seem to be the pro here. Any idea where I might be able to find some guages and a working insturment cluster that is era correct? Or where I can get the ones I have fixed and re-worked?
(quoted from post at 15:45:46 06/05/15) I have a 1959 Case 801B. I am trying to get a parts manual for it, but the only manual I can find is for a 800B. I know the 801B is a variant of the 800B, so would the parts manual be relevent? Any input would be great. Also, does anyone know where I could find a working insturment cluster and guages? Or know where I can get mine rebuilt? Thanks!
The manual you found will probably have the information in it but if your worried about it not having information on the narrow front for the 801b look on the yesterdays tractor parts page type in case 801b parts manual and there you have it.
Byron
I am sure YT here does not have the repaired clusters, John Saeli or Don Livingston both on this site may be able to fix you up with a restored one, not cheap to buy though
cnt
I don't mean to bother you with dumb questions, but how can I contact them, or search the site for their profile. I know there is a way, and I looked around, but I'm not seeing how to do that.
