VAC400
Not a Case question. I was wondering what kind,size, or maker of a machinery sheild you have ,for I may need to have one built. An what would you do differtly now.
Jerry from Ohio
decide what size you you think you want,, then Double it! I would really like folding doors as well,,, sliders work and are Much cheaper but Dang I like the folders I think the big shed here is 65' x 125' I need at least two more just like it, I also Love the 13' door height,,, But I do have a combine that has to fit
Are you thinking of tearing down the other two buildings and having one for storing equipment.? Guess size would depend on what pieces of equipment you intended to store in there, and if you plan on having a work area in it also. Would like to stop by next Monday afternoon around 3:30pm if that's good for you, for the Calendar. Thanks again.
Mike
Mike that will be fine, give me a call ,so I am around , the daughters family will be here and not sure what will be going on. Jerry
Going taller is good advice. The shed we built 15 years ago won't let my current combine in the folding door and barely in the sliding door. The shed we put up last year we went to 18 foot tall doors. Now I can pull in without folding the hopper extensions and can swing the unload auger out inside if I need to. Plus going higher is a relatively cheap upgrade.
