Case 1370 won't turn left
I would check the cylinders, sounds like you had a piston come loose from the rod,, be where I would start,,, cold be something sticking in the control valve as well
Turns out the weld on the upper steering arm that joins the splined shaft to the arm was broken. I got a used one for $200.
