last winter , I had a good mechanic instal a new clutch pak in my 1070 , got it back , and come to think of it never used the pto...although on occasion I noticed it turning so I left it engaged while running doing tillage thinking it would save the brake , ,NOW. hookt pto up to fertilizer buggy ,.. AND NO GO ,,.. lokt tite , with motor off or on , engaged or disengaged , 1000 rpm or 540 ,. damtite !/?,,. I always kinda thought the pto should turn with great effort because of brake drag ,, but that is a clink tite feel I get when I put a small pipe wrench on the shaft / both ways ,, is that normal ??. cheked actuater valve and tried multiple settings ,,. NO Difference , And No Surge Difference or bounce on the tranny pressure needle,, at idle or full throttle ,. Then I took the line off that pumps oil into the pto and at idle let it pump oil into a gallon jug , after about 30 seconds I had over a half gallon ,,. I don't know for sure am thinkin that is not too impressive of flow ,,.. .. phoned my mechanic during serveral of these steps and trials .,. he tells me that he shimmed up the valve this winter to get adequate pressure and is thinkin that perhaps the pto actuator valve should be rebuilt .. probably a seal kit needed becauase of bypassing
