SC Pedistal Weights
Are the AWF and NF late-style front pedestal weights for the SC the same? I am referring to the ones that bolt into the cultivator mounts. I know that the front weights for the AWF DC have cutouts for the tie rods, but it looks to me like a set of weights from a NF SC will also work on an AWF. Unfortunately, I don't have access to a manual which shows these weights.
(quoted from post at 04:34:18 05/13/15) Are the AWF and NF late-style front pedestal weights for the SC the same? I am referring to the ones that bolt into the cultivator mounts. I know that the front weights for the AWF DC have cutouts for the tie rods, but it looks to me like a set of weights from a NF SC will also work on an AWF. Unfortunately, I don't have access to a manual which shows these weights.
Sorry about the pic don't see anything for SC here's a link for the parts
http://partstore.caseih.com/us/
Hope this helps
Byron
I had an AWF SC that had that pedestal broken from loader use. I cut the bottom off a narrow front pedestal and bored the center out to mount the AWF in. I would guess I removed 5 pounds of material to make it work.
The part number on my awf sc pedestal weight is 6288A and 6289A. I am really sure it would fit the tricycle as well. Anyhow you have a number. I am not bright enough to post the pictures I took
(quoted from post at 06:35:19 05/14/15) That is not the weight I was referring to, but I know that the one you have shown does fit into the front of the SC AWF.
I've never seen pictures of the ones widefront posted and their not listed on ant parts list I can find either. I knew about the one behind the radiator. I cant understand why the part is not listed in the parts list. If you do find it can you post a picture part numbers maybe, Id love to see what it looks like.
Thanks Byron
