semiller72
I'm finally getting around to putting the dash and wiring harness back on an almost restored 800 gas and have a couple of questions. The voltage regulator has three terminals on it - F, GEN, and BAT (left to right in the pick). I'm guessing that F goes to the field terminal on the generator, GEN to the other terminal on the generator, and BAT goes back to the battery terminal on the ignition switch.
1. The generator terminals are not marked that I can see. Which is which?
2. And does the other (non field) terminal on the genny also run back to the ammeter gauge?
Thanks ... Steve Miller
