timing marks
On the right side of the bell housing there is a pipe plug. On the flywheel you'll find a 3/16 "hole" or dimple on the flywheel. That's the mark for the mag to fire. There is also a "D" and an "E" stamped on the flywheel, but I can't remember what they indicate. The firing mark is just a titch above the D on the flywheel. I'm sure someone will chime in with more precise info. I can scan a page from the owners or shop manual that shows the mark if needed. Just let me know email is open
Thanks vet! I remember the process now.preciate the kick in the you know what! Hoss also a vet,335 assault helo company 70-72.
(quoted from post at 00:28:04 05/13/15) On the right side of the bell housing there is a pipe plug. On the flywheel you'll find a 3/16 "hole" or dimple on the flywheel. That's the mark for the mag to fire. There is also a "D" and an "E" stamped on the flywheel, but I can't remember what they indicate. The firing mark is just a titch above the D on the flywheel. I'm sure someone will chime in with more precise info. I can scan a page from the owners or shop manual that shows the mark if needed. Just let me know email is open
What I remember is you put a piece of 3/16" welding rod in the hole, on the compression stroke, and center that in the middle of the pipe plug hole.
Ya,thanks to you vet.I was in Dongtam down deep on the delta .We flew Laotian and Cambodian border tearing up the trail every day.Lots of shi! along with those rides! Hoss
