Case 400 High Crop
Richardmo
Here is a Case 400 high crop we got in last week.
The owner had converted it to gas it was on LP.
I have the original LP tank.
tractor runs good and not to bad of condition for coming out of the south.
Not for sure about the transmission
Serial #413 -8068458
I did have the Serial # verified before I bought it.
We buy most tractor site unseen so this could have been missed.
We have more case 730 and 830 high crops will have to some checking.
There's a few more things that don't look quite right to be a 400.
The radiator cap shouldn't go through the top of the hood and the hood should have shallow ribs along the side that go from the front to the back. These would be above the slots on the sides. Does the serial number stamped onto the bell housing match the tag on the dash? All in all it still looks like a pretty good tractor. Good find.
Eli
Also looks like 730-830 heavy cast iron running boards and brake pedals.The engine oil filter looks right for a 400 LP as its tipped out slightly.
It does have case 830 rear end, confirm with my case 830Lp high crop this mornings.
Casting Motor # 6400
Clutch housing # A32046
Transmission # A -26343
Rear drops # A - 7871
