nyhillbilly
Just purchased a Case 430 at auction. Runs great, just has a starting issue I need help with. Uses the 2 6V batteries, after testing today found 1 battery had reversed polarity. Never knew that could happen to be honest. Replaced bad battery, each battery showing 6.16V, but once connected in series, I have only 0.15 volts on tester. Attempt to jump to starter, nothing. Measure at starter, nothing. Where do I look next?
The tractor starts within 5 feet when pull starting, but be nice to actually use a key.
