Ok I decided to change the oil in the trans on my big 400 diesel. All I have is the IT manual and it doesn't do a very good job of giving info. Does the trans take 90w? I took out both plugs under the belly. Does all the oil go in same place under the PTO lever? And the only place to check it is the small plug on right side rear of tractor? Thank you for your help as always an if any one has a operators manual they want to get rid of I would like to have one.
