530 industrial tachometer drve
Zach81
Hey guys, working on the 530 industrial tractor. Having the gauge cluster reworked, so I'm trying to get all the wiring and drive cables replaced. I can't seem to find the tachometer drive. Nothing on the distributor or generator. My dad's 530 ag tractor has it on the generator. This tractor has the autolite gauge cluster with all the gauges lined up on top if that helps with the year. Serial tag is missing.Thanks in advance.
look on left front corner of shifter cover where bolts to tranny there is probably a spot
where cable came out of tranny ,usually filled with silicone . drive usually intact cable
cut off at cover internal drive
if it has CASE-O-Matic the tach drive is on top of the torque tube, if she has a dry clutch it would have been on the gen, the speedo cable goes through the shifter top cover and drives below in the trans case
cnt
