jon f mn
I found a replacement camshaft for my 1030 locally for a good price, assuming it's good. I've asked
around and got different advice from trusted people on whether it needs to be ground before I use it.
One side says yes, grind it and the lifters for a good match, the other side says that's not neccessary
just use it if it's within spec. What do you folks say, if it's in good shape and within specs just use
it? Or always grind them when using one from a different tractor?
