52 Case SC rod bearing
Bhunt
Has anyone out there know what the crankshaft journals Dia should be My 52 SC the manual I have covers the SC tractors but only shows the S series crankshaft Dia. @ 2.500 do they mean all S series tractors including the SC? Also does anyone know what the standard Rod bearing thickness on a new set for a 52 SC is? I haven't pulled mine off yet I'm waiting for a pressure plate I have the tractor split and got some blocks and jacks in the way . Thanks I do appreciate all the help folks have given on this site present and past.
"Crankpin Dia" or Rod is 2.3745" to 2.3755" Clearance should be .001" to .003"
Main Journal is 2.5005" to 2.4995". Clearance should be .0015" to .0035"
(quoted from post at 13:18:29 04/17/15) "Crankpin Dia" or Rod is 2.3745" to 2.3755" Clearance should be .001" to .003"
Wow pretty tight tolerance there. Thanks for the help Byron
Well I have to say I'm surprised that's close to the thickness of a 3/32nd drill bit mighty thin I should have checked them a lot sooner. I had no idea they were that thin thanks fro the help Byron
