It seems to be a bit difficult to shift into any gear even at a standstill. However right now I have the tractor split so I was going to look into why. I don't shift on the fly because it will grind the gears and by the time you find the gear your almost at a stop anyway. Seems like I read somewhere it was not intended to be shifted while moving but I may be mistaken. I have had the shifter off before looking at its operation when I first bought the tractor. Now I do remember it can be a little tricky getting the shifter back in. I believe I just greased some of the areas inside. Can anyone clarify the proper operation of the tractor and any insight as to what to look for to smooth out the Shifting. Thanks in advance
Byron
Byron
