Case VAC Tire/wheel question
Neighbor has a 1953 Eagle hitch VAC with 11.2-34 rear tires on it, that have gone flat. And 11.2-34's are $625 ea from Miller. Based on tractor data .com I see that some VAC's had 28's, and that VC's had 32's. Did the VAC's with 28's or the VC with 32's use the same wheel but different rim, or a different rim and wheel?
Thanks
The cast wheel centers were all different, they wont interchange between sizes.
We own two late VACs one with 34" and one with 28" and also a VC with 32"
Since you have VACs with different sized tires I'd like to ask you what may seem like a silly question. My 46 VAC has 28 inch rims. So how do the three different tire sizes compare in height? For example how high is it to the center of the axle in each case? I suspect the 34" tires will be taller than the 28s but not as much as one might think,do the 34 " tires have shorter sidwalls? Just wondering. Jim
