VAC without hyd
Yes but I think if it is an early VAC and you want to put live hydraulics on the pump gear may be too thick and need machined off. If you are talking about belt pulley hydraulics they will bolt on. Nick
IF I can ask, Why are they called belt pulley hydraulics? What does the pulley have to do with the hydraulics?
I was talking about the set up behind the seat that operates the 3pt lift
