I found a peice of a lifter in the bottom of the oilpan. Has anyone seen this before or think of why it may has happened. Looks like it has been
that way a long time. I have one valve that is unuseable never saw one pitted this bad, looks like at one time most ofthe valves were replaced.
The clutch rod it missing, from the pictures i have looked at it looks like it is just a rod with a 90 on each end, an someone tell me how long it
should be center to center hole? The serial number on the tag is unreadable and i can not find a number on the block but it does have the flat
belt water pump.
belt water pump.
