1070 injector again
greg oliver
I looked up injector on the Case IH online parts and price was $157.00 and on ebay was $48.00. On the barrel of injector was #20668 just wanted to make sure I was looking for the right injector? Seems like a big price difference to me even the reman one was $60.00. He knows he should replace them all but has other parts needed. Just wondered if anyone has purchased the cheap injectors and if they were any good. Thanks, Greg
Call your closest fuel shop, they may be less cost on original Stanadyne 20668 pencil injectors. Doubt they will beat the aftermarket injectors though. I've tried some aftermarket in a JD 4020 that runs fine. Have a local independent repair shop that has had some China injectors fail after a few hours, usually leaks at the brazed joint, so for some engines he will only use Stanadyne original equipment.
Thanks Dieseltech, He wanted to order them and I said let me ask on the Case forum first. Like the old saying if its to good to be true...
I have tried a couple sets of the cheap ones in tractors that see very little use, so far they have run OK. My gripe was the fittings on both sets were not attached at the correct angle. To get the lines hooked up properly it was either bend line on the injector or bend injector line. I bent the line on injector. As Dieseltech mention, same injectors as CASE are available at the diesel shops, last ones cost me $105. Rod.
interstate injection .. Seymour ind , jeff will ship anywhere,, he sent my 1070s to me for around 45 bux each ,, priced my 4020 injectors for same price ,
