Barn Fresh Case Tractors!
Theodores
New User
Have you ever attended an auction and wondered how all those items could possibly fit in 1 barn? Well, below are the Case items crammed into about 1/3 of my barn - we cleaned it out to gain access to the 425 Corn picker (clear against the back wall of course). Spring cleaning is highly recommended, but make sure to have plenty of gas, compressed air, and chains to pull stuff out when all else fails (which seemed to be the rule instead of the exception). I hope you enjoy the pictures!
Pictures?
Neat pictures! What is on the rear of the Ingersol that all the weight is on the front?? Lots of work to keep all the tractors running, have the same problem here.
I have that problem as well, waste half the day to get something out of the back corner, do what I gotta do, hope it don't rain over night and put it all back the next day. Majority each have their own battery so that helps, drives me nuts to swap batteries from one to next. Hope ya don't mind but heres couple pics from when I emptied mine last year (few things didn't make the pic and I've added more since then)
I have a similar problem also but it did get a lot better when the new barn had a door on each end then you only have to unload half the barn!
The picker is going to Minnesota! Another collector looks to actually use it versus sitting idle in the barn!
I'm curious about the green garden tractor. I've never seen one that color. Does Ingersol badge engineer them for some other company?
