case what model?
Skidduh
New User
Hello can u guy Id this case tractor I just got? It was a free b cause the clutch was stuck. I freed it up and it works good now. Also the power steering don't work, the pump has fluid and there seems to be pressure in the lines. I cracked both lines on the pump and fluid came out ta both. I posted a pic but not sure if I did it rite. Here goes[/url]
look on the right side of engine you should see a ste of letters and numbers. Behind the grill usually the right side as you are setting on the seat just past the pump or below the pump should be a tractor model number there.
If you don't see anything at all anyplace pock a part and google that number for a case example injector or carb number example 1111-66-1 case/ sometimes brings the number and source up on ebay or parts here.
