Hi guys, in process of splitting a 1370 for the first time (my first time), between torque tube and transmission. I have a manual and disconnected everything it said, and even a few other things that needed done that the manual didn't mention. We are certain everything is disconnected and then we double checked the bolt count between the housings at 9 total - 4 under belly from torque tube to transmission (2 per side), 4 around top of transmission into torque tube, and one dead center up top from transmission to torque tube (the step bolt). 7 of those are out. We kept the bottom two in, loosened about a quarter inch until we see the housings split, so we are sure to have all our jack heights correct before actually splitting.
Problem is the dang housings are not coming apart. We blocked front wheels and and strapped the blocks tight so the front won't skid. We used 10 ft 4x4 as levers against the rear axles, held tight to wheel with dual clamps, so we have leverage to roll the rearend away when it does split. We bounced pretty good on those wood levers tonight and the housings are not coming apart. We put a little pressure on the jacks to try to split break the seal that way but can't get carried away with that method.
Question is do these normally come apart this hard and if so how the heck do you safely split them? Any help would be appreciated, really need to get this apart and diagnosed and going back together as soon as possible. Thanks!
