This young fellow gets a chance to purchase a very low hr (2200), 2090 CASE from a widow that owned this tractor. It had been parked in a shed for 12 yr since her husband passed away. As a first time CASE owner he was proud of his purchase. He used it for less than a hour before the pto started slipping. Not wanting to damage anything he parked it until I had a chance to look at it. I suspected faulty linings and sure enough that is what I found. He also wanted the oil leak by the engine repaired so I split it. Concerned he might have a problem with linings on the torque limiter plate also I took that apart, sure enough those linings were falling off. Having sat all those years with a little moisture in the oil had taken its toll. I do not have the heart to inform him the brakes and diff lock linings will more than likely have the same fate. These original linings in the 90 series have been known to have this problem in our area. Rod.
