big 400 diesel
Can anyone tell me does napa or another company make fuel filters for a 400 super diesel? I went to the local case/that other word dealer to get them an they didn't have them and wasn't very interested in getting them. I'm tired of messing with them. If someone would have the part numbers it would be great. Thank you!
The "real" 400 uses Napa #3511, Wix #906 for the #2 insert filter. The canister #3 is Napa #33191. Readily available, always on the shelf here in Cen MN. The listing for them is obscure, you're very right there
Bunches of subtleties, larger tool box, PTO brake but most importantly they were Racine produced after serial #810613. Dealers had been known to install the larger cylinders and trim them out like supers, we've one just up the road, bought new, but lower serial #. There's probably more. An excellent article on the Supers was in in one of the Case magazines several years ago, written by Ross Richwein. I can scan and send or post it if anyone's interested
The bigger toolbox has no CASE stamped into the cover. There is a casting "boss" on the steering column where the Case-o-matic lever will bolt onto in the following 800 series. A super will have 4 1/8" inch pistons instead of 4". The block has a different casting number, I can't recall it right now, somebody will post it. Don
