ot turnbuckle
karl h
My New Holland 216 Rake is in need of new top like turnbuckles on both baskets, however I am not prepared to give NH 1200.00 for a new pair. I can find 3/4" rod ends online everywhere, but I am having trouble finding 3/4" CLOSED body turnbuckles to connect the rod ends. I would like to find one similar to what Case used for the park linkage on my 2290 it is just a 3" or so tube with six flat sides for a wrench and is threaded on the inside....anyone know where I can buy some?
Look in a good hardware store that had a good asortment of the larger redi-rod. The coupling nuts are about the dimension that you are describing. You might also look into top links for Cat-0 3pt hitch. Lots of options if you can weld.
Loren
