Re: Case 885
Adirondack case guy
If you are posting on Classic and want to upload pics., scrool down to Advanced Posting Tools. then click onto upload photo, and then select the file or SDE/disc your photos are on. Then select the photo you want, open it, and upload photo icon will appear. Hit that and wait; might be a bit depending on your operating system. A pic should appear in the thumb nail box to right, and once that apperars hit continue icon when it comes up above, and repeat the process. I have never been on modern view, so I can't help you there. Classic is simple and easy.
Loren
As to your issue with the 3pt transport lock, did you pull the white 3pt lever in the quadrent all the way back to select position with engine running to release any mechanical pressure on the deadbolt type lock so it will pull out???
Loren
Sorry, my one track mind was focused in 3pt, not the brake lever going into the diff housing. Rich has addressed that issue for you.
Loren
