Where to use loctite in the engine?
Case 1370.
In the parts catalog, on the same page as the sleeve, piston and rod, there is a tube of loctite (A 150328) in the list.
Why? I can not find in the shop manual where to use it.
Am I supposed to use loctite on any of these parts?
The parts picture might show the replacement sleeves that can be installed in the lower bore where the orings seal. That lower bore area can be bored out to accept the sleeves which are installed with loctite. This is a operation is usually performed by a machine shop. Rod.
Yes Rod that page does show the repair sleeves and I am certain the Loctite was part of that repair process.
Ok!
So that is if the bore is so bad because of rust that you have to renew it by making the hole bigger and install a bushing?
