hydraulic remotes
Nick167
On my 541 it has a loader that runs off the 3pt pump and you use the remote levers to raise and lower it my question is how would I use the remotes without moving the loader?
Nick, could you put some on/off ball valves in the lines going to the loader? then you could simply raise the loader to an appropriate height
close the valves and the loader should be isolated so that all remote flow would then go to what ever you hooked up.
